Typically, they would run around 26, 22 and 10 μS/cm for chloride, nitrate and sulfate, respectively. Now, they're around 5,3 and 2 μS/cm.
I have checked every tubing for air bubbles and done everything else I can think of with no luck. I'm thinking it might be a conductivity detector issue. Any thoughts? TIA
