Our lab has a thermo trace 1300 paired to an ISQ 7000. The electron multiplier was on its way out so I've gotten a replacement from thermo. I've replaced the multiplier before but this time it's been more problematic
Firstly I replaced the multiplier just before the easter long weekend, the manual recommends keeping the multiplier in vacuum for at least a day and I thought over the weekend would be perfect. Also gives plenty of time to get the vacuum nice and stable. I also made sure that the connection from the multiplier to the holder was secure as I've previously had issues with it getting dislodged while putting the assembly back in.
I come in yesterday and do my checks, there's no leak, the vacuum is in my normal operating range (around 60mTorr) and so I do as the manual says, I go into the air & water/Tune dialogue and I reset the multiplier values. Then I go into the autotune and set a tune that will set the detector gain to 3*10^5, this is the EI full tune that comes with the software.
Things seem okay, however at this point I notice the autotune is getting stuck at the "setting Q1 voltage" step. Checking the dashboard at the same time it seems the software is pushing up the voltage of the multiplier and then cycling through Q1 voltages, repeating ad nauseum until eventually giving up.
I've troubleshooted as much as I know how to, I even made sure that I didn't accidentally put the same one back in while I was meant to be changing them. It may well be that there's an issue with the quadrupole that i'm not aware of but as far as I can tell the only thing that's changed IS the multiplier. I'm starting to wonder if I simply got a dud or if there is something else that was wrong that the change revealed.
There doesn't seem to be any blockages or bits in the way, I made sure everything was clean.
I HAVE e-mailed thermo requesting assistance, if they have sent me a dud I'm hoping they'll make that right but I was wondering if anyone else has any input or advice?
Right now I'm going to put the old one back in and see if I can use the last tune file i had as I do need to get this system up and running ASAP. The old multiplier is very much near an end but it is my only other option right now.
