I'm running LabSolutions 5.71 SP2 on a GC-2014 with TCD detector. I know that the software has options to scale to the largest, second largest, and third largest peaks, but I'm trying to figure out set which I want as the overall default. Right now it defaults to the second largest, and I'd like to change that to the third largest.
So far the only way I can make it save anything is data file specific which means I have to do that to every sample. I can't seem to make the overall default change to make it automatic.
Interestingly enough, I have a second similar system that defaults to the largest peak instead of the second largest, so I assume it can be done. I'm just not seeing a way to do it.
Thanks for your help!
