I am very new to OpenChrom, but I need a tool to automatically analyze my GC-MS data, because it´s a huge amount.
Therefore, I found this program and created a batch process:
Denoising Filter
Savitzky-Golay Smoothing
Chromatogram Baseline Subtract
Retention Index Selector
Retention Time Shifter
Peak Detector UI [Template]
Peak Integrator [Template]
CSV Peak Export (*.csv)
But the problem is that if I put too many samples to process the memory of 2GB gets filled up very fast - so how to change that? tried with a openchrom.ini file, but didn´t work.
And the more important thing is that after the batch process I only get a .csv file with only the titles but no data (especially area for specific substances).
Would be very nice if you could help me, thanks a lot!
Best, Tobi
