Is there a way to use the SST/IRC wizard to set up a test case to determine if the r-squared value of the calibration curve passes a certain specification? I usually just calculate it in a table in the summary section, but it would be nice to have it included with my system suitability criteria page as well. I don't see anything in the wizard list that would indicate it can be done, unless it is done by a custom evaluation/formula.
In which case, has anyone figured out that formula and could you provide it?
Thanks!
Brian
