Hplc method for Levetiracetam (antiepileptic drug)
Can anybody kindly tell me the hplc method for levetiracetam using c18 column?
what is the mobile phase used and other hplc parameters?
My other question is whether it is ok if i detect the drug at 205 nm, is it affect the repeatability?
Many methods are reported for this compound. If you search google scholar/ pubmed etc.
If you dont have access to full-text journals you can look in some library around.
You can look in this abstract---may be it serve your purpose.
http://www.drug-monitoring.com/pt/re/td ... 28!8091!-1
Jitender Madan
Division of Pharmaceutics
Central Drug Research Institute
Lucknow, India
Users browsing this forum: Bing [Bot] and 8 guests
