I am writing to seek help for our Dionex Summit HPLC system. It has been showing errors in Chromeleon for a few months now. The result is a disconnected UVD (UV detector), and the sequence run is aborted. (No effective CAPA!)
Troubleshooting attempted:
We have substituted the USB 2.0 cable by many shorted cables, but this did not help.
We have also moved around the used USB port at the back of the PC (linked to the UVD). Disconnect also occurred again.
We thought that it occurred because of the adjacent Shimadzu HPLC and/or the laser printer sending some wrong signals. So, we turned off the printer, and turned off the Shimadzu LC when we were running the Dionex LC. The system still became disconnected, and the run aborted! Note that the power to the whole Dionex LC system is provided by a line-conditioner (so... there should be no spike or dip!).
We have bought a B-to-B USB 2.0 cable, and connected the PC to the UVD, but CM did not recognize this connection.
Did you experience similar events for your Dionex LC? Could you give me some ideas for troubleshooting? I have requested help from Dionex, but got none.
Below is a copy of some error message I got today (07/12/2007):
[Abort] 12:26:36 PM 1.498 {UV} Error reading from UVD170U @ USB-03060504. A device attached to the system is not functioning.
[Abort] 12:37:30 PM {UV} Error reading from UVD170U @ USB-03060504. A device attached to the system is not functioning.
[Abort] 1:49:59 PM 0.373 {UV} Error reading from UVD170U @ USB-03060504. A device attached to the system is not functioning.
[Abort] 1:49:59 PM 0.373 {UV} Communication error: 8.
[Abort] 1:49:59 PM 0.375 {UV} UVD is not remote.
Thank you
Alfred
