I have a Thermo Surveyor HPLC setup with the following:
MS Pump Plus
PDA Detector Plus
Autosampler
Computer:
xCalibur 4.0
LC Devices 3.0
Windows 7
Ethernet Switch
I followed the manual and have the switch wired correctly. All connections are made on the instruments. The MS pump is detected through xCalibur but the other two are not. I assume there is some ethernet setting that I am missing to get those two to talk properly. Does anyone have experience with setting these up?
Thanks in advance!
