GC/FID DMSO and column DB WAX (polyethylenglycol)
bonjour,**
I have some problems with a solvent (DMSO: dimethylsulfoxide) and my column DB-WAX. in fact the profile of DMSO is not repeatable and i used this solvent as a diluent for elaborate a method of purity on a other solvent (Isobutylamine). Do you think that DMSO can react with my column?
Thanks....
Dear demi_lune,
because the boiling point of dmso is very high, i think vaporization of dmso in injector should be unstable. therefore the repeatability was not good.
as you know, volatile solvent is better sample solvent for gc analysis. :D
thanks,
bonjour,**
Thanks....
thanks for your response stobs
In total there are 36 users online :: 3 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 33 guests
