The time scale at the bottom of the trace does not appear to match up with the times of each peak, it also doesn’t start at 0 and end at 18 mins (length of run).
I have had a look in the method and can’t see any way to change this. The ‘replot’ section in the method shows start time to be 0 and end time 18mins, also during the run, the time scale on the real time plot is fine.
Have you any suggestions or thoughts which may help
