The fill level in the colum was about 50cm. Diameter 2,5cm.
After the separation (1,5l mobile phase) still a large amount of substance is remaining in the column (Colour pale orange-red). Even by washing the column with Water and HCl (0,1N) did not get out the substances. What has happened? Is the adsorption between substances and Sephadex so high or is there an other answer?
I did not find yet the desription of this proplem in literature.
Thank you for the help
