1. The dashed line on top of the chromatograph that shows the gradient. I have to keep going into the effects window and uncheck this effect inorder to make it disappear each time my new samples have run. Is there a setting to always have that effect off so that I don't have to always uncheck?
2. The fill/color under the peak and within the baseline to not be filled. I can change line colors but I cannot find any setting options for the area below the peak to not be filled with a color.
Any help would be great, thanks!
