I am having a few problems with the 6460 triple quad.
1. I can set up a run and after the first injection the ms goes to not ready. how can I fix this?
2. I have two methods for analysis with similar source parameters and different gradient flows but similar mobile phase. I have tried using the study manager but once on the second gradient, ms goes to not ready thus cannot run through the night. I have to physically change it.
3. How can I set up a method to elute both positive and negative ions.
I have been lurking around and learning much. Any body who's experienced this and a way out? Thank you
fredddie
