ICS2000 columns cleanup
I performed a columns cleanup (AS-11-HC guard and separator) followed the instruction in the manual, to solve a problem of reduced retention time and floride tailing. The cleaning solution I used is 200mM in 80% Actonitrile. It didn't help. Any advices?
I also found that it took so long (>1day) to bring the background to be less than 1uS after the cleanup. Is this normal?
-Aster
Here are chromatograms showing my problems with retention time.
https://www.dropbox.com/s/seimgjp0j7pn4 ... e.xls?dl=0
Thanks!
Your column is probably old. Lowering the Eluent concentration and flow rate may improve peak separation.
Thanks for comments! Our columns are quite new, used for only about 400 analysis ( but some of the samples have high salinity). A lower eluent con helps a little while reduced flow rate doesn't.
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
