One more question about ML 4.1. I have a sudden drop in my baseline when acquiring analog data (see screenshot)
The parameters I use for the UV detector (Agilent 1100 VWD) are as follows:
Attenuation 250 mV, Zero offset 5 %, response time 60 ms.
Any idea where this could come from and hot to resolve it?
Thank you,
Jörg
PS.: On the same machine running chromeleon (dual boot system) the baseline does not show this drop.
