Processing Empower Chormatography with Chemstation
Would anyone know if its possible to process chormatography generated in Empower (Empower 2 Build 2154 Feature release 3 Service Pack2) with Chemstation? We have the capacity to go the opposite way with being able to process chromatography generated by Chemstation in Empower.
If this is not possible, can you do a blank injection subtraction with the version of Empower I've meantioned above?
Thanks in advance,
Rob
I have a copy of the waters Technical document -Step by Step guide to LC baseline Subtraction in a PDF document.
I used it in a previous job with Empower 2 software
E-mail me at gknox@pos.ca and I'll send you a copy.
Hi JGK,
I was wondering if you still have that Tech doc for the baseline subtraction, if you do, is it also possible to get a copy of it?
Greg
Hi JGK,
Greg
Just send me an e-mail and i'll send it by return
JGK,
Any chance I could get a copy of that PDF too? Pretty please?
:D
If Waters has an Export to AIA (*.cdf), the Agilent ChemStation will import these files for processing and reporting.
Dear,
Am I still get your document about Empower for baseline subtraction
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
