Regarding analytical method validation
Is there is any specific order in which the validation parameters are to be performed (example starting with Specificity, Linearity, precision etc.) or can it be done at our convenience.
No particular order is required. It's a good idea to set things up so that you can get the most information from the least effort (for example., linearity and precision can be done from the same experimental data set (along with LOD and LOQ if those are required).
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
