I am trying to export chromatograms to PDF files from Empower 3. We generate an assay result set from each sample set which I can export using a report method and export method without any issues. We then also create a process only sample set which is used to process for related substances. The result sets produced from this cannot then be exported. I would rather not have to manually report each chromatogram and print to PDF individually.
Is this 'hard wired' into the software, or is it a system policy that can be changed?
Any advice or workarounds would be greatly appreciated as I have something like 300+ chromatograms to export!
Mike
