The UV detector was good for all. I want to be able to confirm all peaks in one run. I don't want to have to change columns for confirmation. Buying a new detector is an option. Can I do this with a Diode array detector in place of the FLD? Would I still use the VWD detector? Will a VWD and DAD confirm each other?
