Sample volume in FFF-MALS
Questions about Multi-Angle Light Scattering coupled with Size-Exclusion Chromatography or Field-Flow Fractionation
What is the typical volume or mass of the prepared sample in FFF-MALS?
Volume for FFF-MALS is very flexible, ranging from 1 µL to hundreds of µL. The sample amount is more limited to avoid overloading: typical is a few µg, but we can use a semi-prep channel and then increase the load by a factor of 100 or more. Hence the initial sample concentration can be on the order of 10 µg/mL or higher. Less material would be needed for samples that are larger than hundreds of kDa in MW such as VLPs, vesicles and nanoparticles.
[answer provided by Christoph Johann, Ph.D., Wyatt Technology]
Daniel Some, Ph.D.
Principal Scientist
Wyatt Technology Corp.
Most users ever online was 599 on Tue Sep 18, 2018 9:27 am
Subscribe to our eNewsletter with daily, weekly or monthly updates: Food, Environmental, (Bio)Pharmaceutical, Bioclinical, Liquid Chromatography, Gas Chromatography and Mass Spectrometry.
