Is easy and reliable quantitative TLC using staining reagents possible? Yes, without a doubt.
There is a brand new TLC analysis software tool available that makes it possible to do hassle free quantitative TLC in minutes. It has been developed over the past two years and is now being used daily by chemists.
The tool is called JustTLC and uses the digital images captured from TLC plates to do the calculations. Use e.g. your ordinary office scanner or digital camera to acquire the images that you need.
It has been scientifically proven that JustTLC gives very accurate quantitative results suitable for high-throughput screening or physical organic investigations.
JustTLC is packed with advanced features that make it a simple task to display, analyze and draw previously impossible conclusions based on TLC plates.
You can find the published article by following this link:
http://dx.doi.org/10.1016/j.chroma.2007.07.029
More information about the tool and a free download is available at:
http://www.sweday.com
I just would like you all to know that what previously has been troublesome now is possible with a few clicks in a tailored, reliable and straight-forward software tool.
Thank you!
Gustav
