Zeleni Mai n Features:
Full Control - Zeleni is able to load method to the SolventTrak unit and set the valve to the waste position.
Simultaneous Data Acquisition- Zeleni is capable to acquire data from up to 100 SolventTrak units simultaneously and record data instantly in a secure database.
Performance Report - Zeleni can generate a report that can be used to demonstrate the performance of the SolventTrak in each chromatographic run.
Configuration Options - Zeleni can be easily configurated to be operated by ethernet, wireless or computer COM port.
User Privileges - The users can be configured to have different privileges according to the laboratory task and responsibilities.
Electronic Record Compliance - Zeleni is designed to meet the electronic record standard requirements.
• Password expiration
• Password length
• Entry attempt limit
• Audit trail record
• Method History
