The chromatogram-signal acquisition board of N2000 workstation is the bridge connecting the chromatogram and the computer. The chromatogram-signal acquisition board itself contains a single chip processing system which is set in a shielded shell alone, and equipped with independent external power supply, imported with original packaging 16/24 (optional) high-precision A/D (analog to digital) converter chip (which integrates PGA programmable magnification, Gaussian low-pass filtering, zero, full scale, background, disorders and other auto-correcting functions). Resolution: full scale +-1uv (ensuring the linear feature of full scale).
The linear of the chromatogram-signal acquisition board of N2000 workstation:
(1) Auto-zeroing function for temperature drift:
With the development of computer technology and the improving of chip integration, the computers
ran faster, which makes the temperature of computer cases much higher. The auto-zeroing function
for temperature drift, preventing the acquisition board from being influenced by the temperature
changes from outside and of the acquisition board itself, ensures the reproducibility of the
chromatogram analysis.
(2) Data error automatic calibration function:
Utilizing advanced dynamic memorizer to continually record and accumulate error data, it could
automatic calibrate while data acquisition, minimizing the impact of the errors.
The hardware of N2000 chromatogram workstation:
It could work as universal type chromatogram data workstation, and be connected to ordinary
chromatogram instruments including Shimadzu, Agilent, WATERS and etc.
Technical specifications:
Software:
Automatically identifying the solvent peaks, tailed peaks, jagged peaks, pre and post shoulder peaks.
Automatically adjusting the parameters (width of the peak, slope) during the analysis process.
Automatically tracking the baseline; automatically compartmentalizing the type of the chromatogram peaks, the start and the end of peaks.
Powerful manual integration function, adding and removing peaks, adjusting the baseline of peaks, regulating the incision ways.
Integral sensitivity is 1 mv·s, the minimum resolution is 0.1 uv, the minimum width of the peak is 0.1 s.
The data could be shared with Microsoft Excel, Word, and other softwares; the data spectrum could be shared with Photoshop, CorelDRAW and other image softwares.
Data re-analysis and filing functions.
Quantitative calculation methods: normalization method, calibration normalization, internal standard method, group method, external standard method and index method.
Hardware:
Dual channel, external type.
Output: -5 mv to 1.7 v
Input impedance larger than 10 MΩ.
Dynamic range 107, linearity ± 0.1%.
Sampling frequency is 10, 25, 50 times/second.
RS232 communication mode, button-type remote control, also controllable with keyboard shortcuts or mouse menu.
Helen Sun
Dalian Replete Science And Technology CO.,LTD.
ADD: 1-7 No.590 Xinan Road Shahekou Area DaLian,China
Tel: 86-411- 84386566
Fax: 86-411- 83786043
Mob:86-15998589873
Skype:helensun1020
E-mail: dl_replete@hotmail.com
Website: http://www.replete.cn
http://www.china-replete.com
