Each pump has a range of 0.01 to 50 ml/minute and may be used isocratically or with others, to create a high pressure mixing gradient. This makes for smooth, easy and reproducible transitions in scaling up from analytical to semi–preparative work.
http://www.cecilinstruments.com/adept-pumps.html
Cecil Instruments Limited
Milton Technical Centre, Cambridge CB24 6AZ
Web-site:- www.cecilinstruments.com
Email: - info@cecilinstruments.com
