Chromatography data system
Posted: Tue Feb 19, 2019 11:16 pm
Hello all,
I am looking for a chromatography data system to replace a TotalChrom/TC Publisher setup for a Perkin Elmer HSGC. The data system needs to only collect the signal from two detectors. The HSGC parameters are set up on the instrument.
I'm not sure what software is out there, so I'm asking for recommendations.
Here is what I'd like to see in the software:
1. Database managed
2. Audit trail
3. Customization of reports by the lab/IT staff or be able to connect to Crystal Reports or other external reporting software to create reports.
4. Be able to add fields to the sequence table.
5. Be able to import a csv into the sequence table.
6. Be able to export results as a csv so it can be sent to a LIMS system.
7. Hopefully a demo system I could try.
Thank you for your help.
Christy
1. Database managed
2. Audit trail
Christy
