Empower 3- whats the difference Save Result/Save all?
1 post
I often integrate samples through channels so if, for example, im integrating a sample and quantifying it off a standard, ill bring the sample and standard into channels, open my processing method/method set and when I set my integration paramaters and finish calibrating/quantitating my sample, I will go to File>Save Result, which throws my result into the Results tab. However, what happens if you hit File>Save All? Whats the difference and is it due to the fact that the method set as opposed to the processing method is opened?
1 post
