I'm using a UHPLC Dionex Ultimate 3000 RS system connected to a ASUSPRO. Sequences are run from Xcalibur. The sequence I was trying to run now was aborted in the middle of the run. The following error message was displayed:
Cannot start sequence. (Device is not remote. The batch will need about 4100K disk space on drive c: (59470000K available)...
Any experience with such a problem? Any help very much appreciated...
