serve connection trouble galaxie workstation
Posted: Tue Jun 26, 2018 2:57 pm
by anbulf
Hi
I've a varian CP 3380 GC working with the software Galaxie Workstation, today when I tried to open the software a trouble message was send.
The message said: ‘Server connection: Unable to connect: EnxPooledTransportException during logon procedure:
NexusDB: <unnamed TnxWinsock Transport instance>: Cannot locate or connect to network server
Looking informatio found that a possible solution is to run a tool called: 'fixGalaxieServerSettings.exe’ but I can find it.
Someone can help me?
Thank you
Re: serve connection trouble galaxie workstation
Posted: Thu Nov 15, 2018 12:32 pm
by Dr Bob Lott
Hi, did you get a copy of the tool and have you fixed the issue?
Posted: Fri Oct 16, 2020 10:40 pm
by Madankumar2020
Hi Bob,
We are looking at old message strings related to issues with HPLC Varian Galaxie software issue.
I saw that you had a posted a solution to this problem that we are having while logon and shows "server connection unable to connect enxpooled transportexception during logon procedure at 142E830: NexusDB: <unnamed TnxWinsockTransportinstance>: cannot locate or connect to network server. [$2C0E/11278]" error.
So, If you have this file "fixGalaxieServerSettings.exe", please send us at madankumar.arumugam@unmc.edu. If
you don't have the file, any insights on how to get it Or send us the solution to solve this issue.
Your help would be greatly appreciated.
