So the value in my component editor is (50/100)*(99.7/100)*(5/50)*1000 = 4.985 mcg/mL.
Therefore my sample weights are typically 150mg so I enter this in the SampleWeight field as 150000 to match the mcg unit.
Is this considered weight adjusted? My Excel sheet currently multiplies the area of my active peak in each bracketing standard by the theoretical standard weight and divides by actual standard weight.
