I'm having an issue in processing multiple channels in empower.
I have one sample set with two waveleghts (2 channels) and I have to process rel. substances. One channel is used to process the standard and samples, and the other is only used to process one peak from samples, but i need to quantitate that peak using the curve genereted from the standards in the other channels. But for some reason empower associate the curve only to one channel and i cant quantitate the peak with that curve.
Any ideias to solve this?
thanks
