Simple Custom field in theory!!!
Posted: Mon Sep 04, 2017 11:25 am
I run 2 injections of Blank, sample is labelled Blank. I need to calculate the amount in percentage of active as a function of the average area of the following standard injection. So I have a Custom field which calculates the average area of my active in the standard. However my percent carryover is only giving a result for the second injection. I need one result per injection.
Here is my formula, can you help?
Peak, Real, calculated, Result Set Only.
=(Blank.%.(Area)/Average_Area_Std)*100.
