I would like to ask how to set default syringe size using nanoliter adapter option in Empower 3.
As far as i know, i need to go to run sample to select 5ul and the nanoliter adapter option which must be checked.
However, when I log in another computer, the default syringe size is not check again. Even different user using the computer that i have already set the default of syringe size, the other user does not have the default setting of thr syringe size.
I would like to ask how to make all the computer and different to have default syringe size? Is it possible to be set in the instrument method?
Thank you in advanced.
Agnes
