I have found two ways of displaying a background subtracted chromatograph:
First Method
1. In 'Data Analysis'
2. File-> Subtract Blank Run... --> Select file to subtract blank
Using this method I can't find a saved *.SBS file...
Second Method
2. In 'Signal'
3. Load 2+ signals
4. Click the button with two chromatographs and a yellow line 'Subtract the last signal from all other signals'
But I can't figure out how to save the adjusted chromatgraph...
In and all help/comments are appreciated!
Thanks you!!
