GC Data Visualization
8 posts Page 1 of 1
Is there any way to evaluate my GC chromatograms at home. Until now, I intigrate the peaks and take a screenshot.
Stupidly, I sometimes notice, you could do better with the integration and then have to wait again 1 week until I get to the device.
For tips, I would be happy, work with a PerkinElmer GC clarus 500 + software and got the result data in .raw files.
Do you mean you want to store the results of your integration back to the raw files in the same format as the original software? So that you could import it back to the PerkinElmer system?
Software Engineer at elsci.io (my contact: stanislav.bashkyrtsev@elsci.io)
No, I want to open the saved .raw data at home and reintegrate the peaks there in case I made a mistake in the lab.
The problem seems to be that I need exactly the software that came with the GC device to process the data. I hope I am wrong and there are other programs?
Right now I'm taking a screenshot of the integral, and I think it's important to mention that I'm integrating manually and not relying on the software.
Other software can support reading raw files (we can certainly take a look at it in Peaksel if you want), but it's possible that they will use different units and algorithms, so the results may differ. Usually the biggest difference is in how they detect peak boundaries, but even for manual integration there potentially could be differences (some software may employ Trapezoids to calculate area, others may use Simpson's rule), though I'd be surprised if the differences were large.
Overall I'd be cautious comparing results between different software.
Maybe have a look on OpenChrom by Lablicate: http://www.openchrom.net
It may work for your purpose, if you're free to choose the software.
But you may need to reprocess all your data, as I wouldn't mix integration from multiple softwares.
Thank you, the Software looks nice, maybe I give this a try...
Thank you very much! With this program I can view and zoom into the .raw files, that is great and exactly what I need.
Our UniChrom provides data processing for free
Download:
https://www.unichrom.com/chrom/ucdle.php
List of file formats supported:
https://www.unichrom.com/chrom/uc-ffe.shtml
Spreadsheet reporting in very innovative way:
https://www.unichrom.com/calc/calce.shtml
8 posts Page 1 of 1
Users browsing this forum: Majestic-12 [Bot] and 1 guest
