Im pretty new with Empower. I have a processing method, it integrates and quantitates concentration based on my standard curve. Recently (this has not happened before), if I manually integrate, the Area turns to 1 and the percent area says "1.#R" and it will not quantitate which ever peaks i manually integrated. At first i thought it could be an issue with "falling off the curve" but i could pick it up and put it back where it was and it does the same thing, doesnt matter how much more or less im integrating.
Thanks!
