Anyone know if the 3900 should work with MS Workstation 6.9.3 or 7? When I set up the networking they talk to each other and the 3900 grabs an IP but then MS Workstation says its not a 3900. Exact error is:
Module 44 is not a 3900 (39XL)
But even the Ethernet setup subroutine sees it as a 39XL
Firmware updater also said it's not recognized but still updated the firmware... Odd.
