I'm working on CE P/ACE MDQ system,
there is coolant leakage problem, we have checked, all tubings are proper but still coolant is leaking.
It seems that coolant is coming out from the opening which is provided for relief valve.
Any suggestions what I can do?
Also, Can I use water for coolant as We dont want to purchase new coolant because we will not be using CE anymore.
