Clean up signal in capillary electrophoresys
Posted: Fri Dec 28, 2012 2:23 pm
HELLO!
I'm working with CE, Agilent B. 4.2 a method for the determination of anions. I am using different wavelengths in the trial and I worry that one of them (470 nm) gives me a noisy signal. Can anyone tell me how I can clean up the signal? NaOH solution use as flush.
Thank you very much for your help!
