https://www.dropbox.com/s/e98y4zlxp07eu ... M.jpg?dl=0
Then I tried the following:
Changing filters for both guard and main column/Using the 10 times concentration of eluent to flush the column/Using 1N HCl to flush the column.
Later on, it got even worse.
https://www.dropbox.com/s/t00k0nqskry16 ... M.jpg?dl=0
Do you guys know what else should I do? Regenerating the suppressor? (Is that because the suppressor had been left unused for too long time?)
BTW, Im using:
AS-22 Fast 4X150 mm main column/AG-22 Fast 4X30 mm Guard column/AERS 500 4mm suppressor/Dionex ICS-1100.
