My plan is to run stainless from the three reagent gas cylinders(methane, isobutane, ammonia) into an ammonia-rated stainless manifold/selector valve. My problem comes in that I'm planning on mounting this on the wall behind the instrument, and need to get the CI reagent gas out of the manifold and into the MS.
I have a very strong dislike of working with stainless tubing, and only do it if there's no realistic alternative.
For obvious reasons, I like for my plumbing going directly into the instrument to be flexible.
For that reason, I'm wondering if it's even possible/safe to have my final connection from the manifold to the instrument be flexible PTFE.
Does anyone have any experience with this?
Of course, if it IS unsafe, I may ditch using ammonia completely and just run copper for methane/isobutane.
