next prob:
Did you check the lenses ? did you clean the source before you did the electronic check ? after a while the pins to connect the lenses get loose and cause problems like that. If the detectors come close to 2000 they might work weird. maybe you have a replacement one to check.
I didnt read the whole post but most of the time the varian maschines have easier problem than the people think.
Sometimes i just remove everything (Quads and source) clean it and put it back together and it works again.
When it comes to problems with the boards is a pain to check every voltage.
