I am new to the masshunter unknown analysis and I have learnt to create a report using Agilent built-in templates .
However I noticed that the “Sample Chromatogram” in the Agilent built-in template : LSR_NonTarget_Details prints out the entire chromatogram for the run time range .
I will like to check with you all if there is a possibility to include the zoomed in portion of the chromatogram for a retention time range e.g 10-11 mins to the report.
Thank you so much for the help.
