Unified name for added or lost "fragments" in Mass Spec
There are different ways an analyte can react in Mass Spec. It can:
- Receive a positively charged ion like H+
- Receive a negatively charged ion like H-
- Loose a neutral fragment like BOC
- Receive a nuetral fragment
- And it can be fragmented into 2 ions
I'd like to create a table with all of these included. But I don't know how to name such table. It would contain something like:
Code: Select all
Change  | Effect on Analyte charge
[M+H]   | +1
[M+Na]  | +1
[M-BOC] | 0
Some people call them adducts (which doesn't seem to make sense when it's removed), others - fragments (which doesn't make sense when it's added). Is there some common term that would unite these?
Software Engineer at elsci.io (my contact: stanislav.bashkyrtsev@elsci.io)
Species?
If this table is just for internal or personal use, that would be a good broad, general term.
"Have you tried explaining it to the rubber duck?"
Naah, that's too generic :) Seems like there's no common term and I'd just have to list them as Adducts, Fragments, Ions.
Users browsing this forum: dkritz80 and 1 guest
