by
wss » Fri Aug 25, 2023 12:16 am
As long as the specs are similar I'd say go for it.
The biggest difference with a cheaper pump is likely reliability under continuous operation, but if it's an older instrument and you're just keeping it going, it's probably fine. I've never been terribly impressed with the reliability of Varian/Agilent branded pumps anyway and usually go with Edwards, Vacuubrand or Pfeiffer, but your experience may differ.
Alternatively, a pump overhaul kit might be better value still if you're happy to do the overhaul yourself. The pump seals are often, but not always the culprit for severe leaks. We refurbish our own Pfeiffer and Edwards RV pumps for our GC-MS's in the lab this way, the kits are around $400AUD from memory, which is much cheaper than a new or refurbished pump.
