Lately I'm getting results that are too good: both are less than 0.1%
I'm also seeing isotope ratios that can't be right. I've seen as high as a 40% ratio of 19:18.
If I run a Standard Tune, it shows 18 and 28 at about 0.5%.
Any idea what's going on? A dirty source maybe, or an issue with mass assignments on the low end?
