Just wondering if anyone is working on a fixed gas application involving Hayesep DB packed column, would you mind sharing your retention time? Just so I can compare my GC data, I assumed an initial retention time in the GC method.
I am interested in Oxygen and Argon (both measured by the TCD detector against a Helium internal standard-for both TCD detector and column carrier gas).
I obtained the peaks, according to the totalchrom automatic integration, Oxygen and Argon are detected. However, there are not enough peaks for calibration. I believe if I use an appropriate column retention time, this will enable me to obtain enough peaks to calibrate the gas to the GC in the usual way.
Many thanks,
