I have just fished using a method that uses the back Inlet (S/SL).
I am setting up the GC for a different method that uses the front inlet (PTV).
I have used this method before with no issues from the Instrument or software however today when I go to change to the front inlet it is shown as blanked out and I am unable to pick it as my Inlet for the method.
any Ideas what could be causing this ?
Thanks in advance.
Chemiger
