So the technician came and replaced the autosampler. But now we still have it.
Could it be a problem with the electronics?
As we have installed 2 columns recently, so there has been worked in the place where all the cables are coming together?
Something that I noticed in the manual is that we should do once in a while an auto calibration of the EFC. If I do that, it says that is failed. What should I do?
Can this be the reason of the errors? What exactly does this calibration does?
Kind regards
