Internal Standard for BT (residual solvent test)
Hello all,
I am testing butane, propane, and isobutane for purity and BTEX and residual solvent components. I am considering using fluorobenzene as an internal standard in my GC-FID set up. Is this the best internal standard to use to avoid co-elution? Does anyone do similar testing and use the same or a different internal standard?
Any thoughts?
Mariah
What is your matrix?
Users browsing this forum: Majestic-12 [Bot] and 1 guest
