ascorbic acid
Posted: Sun Jan 13, 2019 12:51 am
by Mohamad
Hello guys,
can someone help me about ran ascorbic acid on GC
Re: ascorbic acid
Posted: Sun Jan 13, 2019 2:38 pm
by rb6banjo
It'll never work. I'd find another way to do it. Firstly, the boiling point is way too high. There are other problems but this is the big one.
Re: ascorbic acid
Posted: Sun Jan 13, 2019 9:32 pm
by Consumer Products Guy
Mohamad wrote:
Hello guys,
Wrong "tool". Would you brush your teeth with a wrench?
Re: ascorbic acid
Posted: Sat Jan 19, 2019 11:58 pm
by Mohamad
thank you for reply. but i have COA from different vendors and all them have GC test and that is the reason make me try to find if there is a method to ran ascorbic acid on GC.
Re: ascorbic acid
Posted: Sun Jan 20, 2019 3:11 pm
So contact those suppliers, suppliers will often share QC methods, some can be adapted for use in finished products. But likely GC was used for stuff like residual solvents, etc.
Re: ascorbic acid
Posted: Fri Jan 25, 2019 3:28 pm
by BMU_VMW
What would you like to know about your acid?
e.g. if you want to check for volatile contaminants than headspace sampling of a vial of ascorbic acid should be possible.
Re: ascorbic acid
Posted: Tue Jan 29, 2019 1:52 pm
by MSCHemist
I believe I tried some derivatization methods (ethyl chloroformate) etc haven't found one that worked well. I think silylation may but you definitely need to derivatize as I believe ascorbic has both too high a boiling point and is not thermally stable.
Edit yep silylation with HMDS in acetonitrile.
https://www.sciencedirect.com/science/a ... 3503001919the complication being it has to be lyophilized because normal evaporation under heat/nitrogen degrades it.
I have a request for it now and I am looking into UV-VIS assays.
